what is this TOSLINK connection called? And cable name?
Discussion in 'AV Receivers & Amplifiers' started by thestorm, Mar 14, 2002.
  1. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    Hi all
    Please can you help. I need a lead which has the above connectors at BOTH ends. What is this cable called?
    And what's the name of this connection?
    I've attached a pic of the connection.
    Cheers,
    Shaz
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,493
    United Kingdom
    +2,030
    That´ll be Coaxial then.;)
    Ive heard you can use coathanger wire wrapped in clingfilm but I´ve not tried it myself.
  3. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Toslink cable is just a fibreoptic cable for digital audio signals.
    You'll find them at any good AV store. You should also be able to pick up cheaper ones from the likes of Dixons and Comet etc...
    Some people prefer this link over a phono cable for their digital audio. I prefer the phono cable option myself.
  4. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    yeah very smart, very wise... Very funny indeed, u're so humorous. i'm blasting my pants off with laughter!
    i need it for my xbox.... I've got the wrong lead at home,... the one i have has a square connector at one end and a pin like connector on the other hand.
    I prefer electric coax myself BUT some source don't have this eg minidisk and in this case Xbox.
    so what is it?
    Cya,
    Shaz
  5. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,493
    United Kingdom
    +2,030
    Now I´ve got my sensible head back on.
    As alanrob says the cable you need is a Toslink cable available from most cable suppliers normally in 1M lengths.
    Originally designed by Toshiba hence the Tos part of the name.
    Have a look at these suppliers
    www.qed.co.uk
    www.chord.co.uk
    I prefer the Digital Coaxial cable myself but also use the Toslink Optical cable as well.
    cheers
  6. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    ok i'll check out those links, but is it caleld somethingl ike T to T
    or soemthing? As i'm going to be telling someone to get it for me,
  7. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,493
    United Kingdom
    +2,030
    Its a Toslink to Toslink optical cable.
    On the Chord website its the Optichord cable your after.
  8. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    Hi Jase
    As always u're an encylopedia of AV knowledge!
    Thanks a LOT. :)
    Cya,
    Shaz
  9. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    We thought so! ;)
