What is the smallest MicroDV Camcorder ?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Biglad_UK, Jul 26, 2003.
  1. Biglad_UK
    Biglad_UK
    Jul 26, 2003
    707
    Milton Keynes
    +23
    I'm torn between the Canon MV6 and the JVC GR-DVP9. They both look tiny on the web but I haven't seen either in the flesh.
    Can someone please advise which is the smallest/best or throw any addtional camcorders into the pot.
    Thanks in advance
    Simon
    Oh Yeah.....it must be Mac ( IMovie) compatible
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    Be careful with MicroMV as these camcorders are often NOT compatable with editing programmes as it is a Sony only format. A lot of the newer versions of programmes are starting to build in compatability for MV, but not all and not old versions.
    Although slightly bigger, you might be better going for a DV camcorder as all of these will be ok with iMovie.
    Mark.
  3. infomatique
    infomatique
    I have the JVC which I got at a good price from Amazon (in the UK) ... surprise! Much less than the price at Computeruniverse in Germany or locally here in Dublin.
    Anyway I am very pleased with it and I have had not compatability problems (I use Premier 6.5 and a number of other programs). I am using a PC rather than Apple. The unit is very well built.
  4. Peter Shilton
    Peter Shilton
    Jun 8, 2002
    213
    19
    Solihull
    I've got the Sony IP7 and I haven't seen anything smaller.
  5. AndySee
    AndySee
    Aug 25, 2003
    132
    +6
    I thought MicroDV was only used by Sony (in the IP7) The JVC uses Mini DV, so no format compatibility problems. I have a DP3 and really like it, the DP9 has the benefit of DV out and slightly higher CCD. It fits very well in a pocket too.
