What is the shortest Scart lead available?
B
Brakeinup
Is it 0.75M?
I am look for a good quality lead but it only needs to be 0.25M and I am trying to avoid excess cable on my install.
Mad Mikeyboy
On the back of this one can anyone tell me where I can buy an extra long one to connect up my LCD which is going on the wall about 5metres away from my sky box?
Don't want one made up and doesn't have to be anything special. It's not my main viewing TV.
M
Member 34135
Brakeinup said:
Is it 0.75M?
Lindy do a high quality 0.35m scart, looks very similar to the Ixos XHT611.
Andy
pablo99
I've bought all my cables off ebay. Try Fillyourboots. :thumbsup:
Ixos and QED cables can get pricey when you need 5 mtr lengths. Savings on ebay can be very good. :D
Quality usually means all conductors individually screened. I had crosstalk problems with a "quality" scart from Progold. Ixos cable solved that one. :clap:
I have a 0.5 mtr Ixos between the Sky box and my Panasonic E85.
Then three 5 mtr scart to scarts to the Veira mounted on the wall. Ixos 5 mtr component video needed also.
I have QED cables, silver spiral etc, on my hi-fi.
B
Brakeinup
Andy
Thanks - I will have a look.
Trending threads
