What Is The Resolution On VHS Tape
Discussion in 'Digital TV & Video Players & Recorders' started by Garrett, Oct 22, 2004.
Tags:
  1. Garrett
    Garrett
    Apr 21, 2001
    42,105
    2
    167
    The best thief you'll never see.
    +7,644
    I know its an old medium and on its way out but what is the lines resolution for, VHS SP,LP and S-VHS SP and LP.
  2. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    VHS gives you about 240 lines, S-VHS gives you about 400, IIRC.
  3. Garrett
    Garrett
    Apr 21, 2001
    42,105
    2
    167
    +7,644
    Thanks :smashin: do you know the figures for them in LP?
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,523
    Somewhere in South Yorkshire
    +5,996
    Just to be clear about this (sorry if you already knew):
    There are always 576 discrete horizontal lines regardless to machine/type. So the vertical resolution is always 576 (for PAL).
    The maximum number of discrete changes in colour/brightness along each line (which gives the horizontal resolution) is what varies.
    And, as SDC says, 240 and 400 are about as good as it gets.. VHS LP may drop to around 180. SVHS LP may drop to around 350. Depends on the machine. More probably, LP will result in increased noise, rather than significantly reduced definition.
