What is the purpose of "line out"?
Discussion in 'Headphones, Earphones & Portable Music' started by L11, Sep 7, 2005.
  1. L11
    L11
    Jun 2, 2005
    323
    +7
    Just wondering because i plug my HD5 into my amp usin the headphone socket and not changing it to 'line out' and it sounds fine..
  2. Anonyrat
    Anonyrat
    No reason why it will not sound fine - it is just that the line out is a hotter signal and you should get a better signal(less distortion ). Just don't listen to the line out through headphones, it will distort and blow whatever is between your ears out of your nostrils.
    Also Line out is direct it doesn't use the built in EQ's.
  3. KiNeL
    KiNeL
    Aug 18, 2005
    333
    Essex
    +7
    Line out provides an industry standard level and impedence match for feeding into a HiFi system. By using the headphone setting, theoretically at least, you are degrading the signal to noise ratio of your amplifier evidenced by you having to turn the amp volume up higher than you would normally when listening to a CD player for instance.
    The ultimate arbiter though is your own ears and if it sound "fine" to you don't worry about it.
  4. L11
    L11
    Jun 2, 2005
    323
    +7
    Thats what i wanted to hear really. Thanx
