What is the PTAE100 like?
Discussion in 'Projectors, Screens & Video Processors' started by nwgarratt, Aug 2, 2004.
  1. nwgarratt
    nwgarratt
    May 5, 2002
    27,477
    +3,117
    I know very little about projectors.
    I have the opportunity to get a seconh hand Panasonic PTAE100 for £600 but in mint condition.
    Are these any good and will they work with progressive DVD players?
  2. rogeralpine
    rogeralpine
    Oct 28, 2002
    573
    16
    You can have my "mint" AE100 for £500! :smashin:
    Certainly will work with a prog dvd player - not a bad budget machine, but time has moved on. £600 would seem a little OTT.
  3. nwgarratt
    nwgarratt
    May 5, 2002
    27,477
    +3,117
    I am having it on a trial period.
    Also, it won't cost anything as it will be part of a swap of equipment.
    As it will be my first projector, I don't want anything to fancy. Does it have a RGB scart. I have seen conflciting specs on that. If so, I could put my digibox through it.
  4. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
    Ive had a AE100 for two years they are a great little projector but things have moved on and they are showing their age. I don't think its worth £600, i would not pay anymore than £450 and for that it would have to be new.
    They do not have a scart input. Have a look at the Information for Newcomers thread.
  5. nwgarratt
    nwgarratt
    May 5, 2002
    27,477
    +3,117
    Has anyone got a link to a downloadble manual for it?
    I found some links on here and the web but they don't work anymore.
  6. windfall
    windfall
    Oct 19, 2003
    2,422
    48
    LFC Kop End
    +65
    Are you after the sales brochure - I have this in PDF format.
    When Someone says mint - what do they mean?
    I would imagine a mint PTAE100 would have low hours - IMHO any pj should be immaculate unless it has been used all over the place for presentations?
    Do you happen to know how many hours it has on it?
    I think you can still pickup brand new PTAE300 for around £700 or less.
    For that you'll get more brightness and higher contrast ratio's.
    £600 is steep even for a PJ which I consider to be pretty good in darkened conditions.
    I certainly have the brochure in PDF if that helps - just PM me and I'll email over to you.
    Tone
  7. nwgarratt
    nwgarratt
    May 5, 2002
    27,477
    +3,117
    I have been testing the projector for an hour or so and I am very impressed. I had it connected to a Ebench KH777 on component with progressive scan. I am not sure if the progresive was on or off. There doesn't seem to be anything to switch on or off.
    I watched parts of LOTR FOTR, Fifth Element, SPR and Goldmember.
    I have only got a slide screen and it wasn't quite big enough to show the whole picture. It still looked very sharp and Goldmember was very colourful.
    I was told the bulb had been used for 300 hours but it has been used for over 1000!
    Is there any big difference between progressive component and normal component? I have a Sony NS900 with just component and will be trying that tomorrow.
    As it is a trial, nothing has been swapped for it or money taken.
    I was talking about a user manual rather than a sales brochure.
  8. windfall
    windfall
    Oct 19, 2003
    2,422
    48
    LFC Kop End
    +65
    IMHO the progressive mode from my Yamaha S540 beats the poo out of the intrelaced, just on the menu's of the dvd player when it's switched show a vast improvement.
    I would not pay more than £450 for the "mint" pj mate - I have seen AE100's passing around for less for 1000+ hours on the bulb.
    When you powered it up was the bulb on low level or normal? This will make a difference in the long term.
    I am seriously considering an upgrade myself but would be looking for a pj with higher pixel def - 1280x720 kind of ilk with higher brightness and contrast ratio.
    Again I think the image in a darkened room from the PTAE100 is very good. And I think for a couple of years you'll be happy with it.
