What is the latest generation ipod
Discussion in 'Headphones, Earphones & Portable Music' started by Benjamin, Apr 30, 2007.
Tags:
  1. Benjamin
    Benjamin
    Can anyone help me, :lease: on the uk amazon site the latest 80gb ipod is listed as 5th generation, on the us site it is the 5.5 generation and on ebay it is the 6th generation, which is the correct one?
  2. sven256
    sven256
    Jan 16, 2004
    93
    manchester
    +6
    generation 5.5 i think is the correct one
    as there was a slight revision to the original to the original generation 5.
    just a slight improved screen and a bit better battery life.
    on ebay i have no doubt they are just putting generation 6 to sell the product (usual rip off) they put generation 6 (which is incorrect) someone else puts generation 5 which is your average joe on the streets going to buy.
    clearly he/she will buy the generation6 thinking it is newer therefore better.
