What is the job of a power amp?
Discussion in 'AV Receivers & Amplifiers' started by Yards, Dec 25, 2004.
  1. Yards
    Yards
    What should a power amp do to your sound?
    Simple question I know, but a simple answer is required!
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Reasonably simple. A little bit of amplifier theory will tell you that to generate a signal that a speaker can use from a source (such as a CD player) you need to be able to change the volume and amplify the signal to a level that will be able to drive the speaker.
    A little bit of theory will demonstrate that the best way to do this is to use a low noise first amplifier stage (the preamp) and a more beefy power amplifier stage (the power amplifier). The theory will demonstrate that the noise level of the power amplifier in such a system is far less relevant.
    Essentially, the preamp does the signal processing whilst the power amp will amplify the signal level to a suitable power for the chosen speakers.
    I hope that helps (it confused me) but Merry Christmas anyway :hiya:
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The short answer: the power amp should do nothing to your sound, i.e. it should remain neutral and merely amplify what comes in.
  4. Poolsharkie69
    Poolsharkie69
    Ok to make it even more confusing...how do you know when u need to buy a pre amp? I have been toying with the idea. My set up is in my signature.
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Your integrated Yamaha amp combines the 2, (hence it being called "integrated").
    A seperate pre-amp would be used with seperate power amps.
  6. Poolsharkie69
    Poolsharkie69
    Ok...for a dumb guy like me that woudl mean no I don't need one then.
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,825
    London
    +1,092
    A pre-amp is also known as a processor.
  8. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Not right :lesson:
    A pre amp is the control part of an amplifier, it takes the inputs and feeds them to the power amplifier.
  9. Tejstar
    Tejstar
    Dec 4, 2002
    22,825
    London
    +1,092
    :oops: I was always under the impression that some people refer to the pre-amp as the precessor. You learn something every day!
  10. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    The term processor is more appropriate for AV equipment. The digital signal is "processed", then fed to a "preamp" stage (usually within the processor) and then sent to a seperate "power amp" stage. Of course you can also "process" analogue signals by adding DSP's to them or similar.
    Integrated amps combine all 3 stages so everyone has them, even the most basic micro stereo system will have a preamp and power amp stage. :)
  11. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,605
    7
    167
    Birmingham, UK
    +10,474
    That's the problem - a little knowledge can be worse than none at all. Specially if it's given with an air of authority.
    I'm glad there are plenty of experts around here to correct mistakes.
  12. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    It's a big problem, and the mags have a lot to answer for in this respect IMO.
    It does help emphasise the benefits of these (and other) forums though. Knowledgable people have as much time as necessary to explain things to the interested. :)
  13. Tejstar
    Tejstar
    Dec 4, 2002
    22,825
    London
    +1,092
    So am I right in saying that pre-amps are more common with stereo equipment?
    And is it possible within AV equipment to get separate processor, pre-amp and power-amp? As far as I knew, I thought within the home cinema route you'd normally go for processor and power amp if you weren't taking the integrated route?
  14. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Seperate preamps are more common in the stereo arena. I've certainly never come across a 5-channel preamp!
    The "processor" you mention will contain both a processing stage (where all the DSPs, bass management etc are implemented) and a preamp stage.
    It's mainly nomenclature but your signal will be processed in the digital realm (ie. DD, DTS, DPL , bass management etc). Then it will be sent to the preamp stage (usually as analogue) where the signal will be amplified to a level usable by a power amp. This preamp stage will have a very low noise level. Then, the preamplified signal is sent to a power amp stage which boosts the gain to a level which can drive speakers. Seperating the preamp and power amp (rather than just having a big beefy preamp) is to reduce noise in the final output signal.
    The important thing to remember is that the part of your system with the volume control is the preamp stage. The part that's rated at "80Watts per channel" for example is the power amp stage. The bit that does any digital processing of the sound is the processor. As I've mentioned, an integrated stereo amplifier will combine a preamp and a power amp in the same box. An integrated AV amplifier will combine all 3 stages within the same box. An AV processor will combine the processing and the preamp in the same box.
    I hope that makes some sense :suicide:
  15. Tejstar
    Tejstar
    Dec 4, 2002
    22,825
    London
    +1,092
    Very well explained John - thanks for taking the time to explain it to me :)
  16. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Glad to help, there's quite a lot more to it when considering the noise implications but that covers the basics of what does what.
    It's the same principle as CD players combine a transport and a DAC in one convenient package. If you don't understand what the words mean though it gets a bit complicated. :)
