Basil Plumley
I have a Sony BD-P760 connected to an Arcam AVR300 via the 7.1 channel analogue inputs...the player decodes just about every format internally - including DTS HD MA ES found on the LOTR discs...but I'm getting the age old problem of lack of bass.
The Arcam has a setting in the subwoofer setup to allow you to add 10dB to the LFE channel when using the analogue inputs, but when flicking between it on and off whilst running the test tone on the Sony, it barely moves the needle on my SPL metre - so it's barely giving 1 or 2dB increase when it's supposed to give 10...
The only way I can counter it is to turn all the channels down to 10dB below what the sub is set at on the Sony (so in effect, all of them are -10 or more) and leave the +10 on on the Arcam...but surely this is giving me an overall +20dB increase in the LFE channel - isn't it...? Plus this means that to get the sound at anywhere near normal listening levels I have to run the volume at 90%...
Any help would be greatly appreciated...
of Epsom...
