Quantcast
what is the ideal height for wall mounted surrounds?
Supra
As per post title, what is thge ideal height for wall mounted surrounds?
I have uptil now been using kef q55.2s (floorstanders) for surround duties. I have just today purchased a pair of cdm snts to match my fronts.
I have read lots of posts, with varying information and opinions in regard to the ideal height.
Anyone have any opinions from real world experience.
I am considering puting them at just above light switch height as installer 09 has done, what do you think?
:lease:
Supra
thanks beatie boy, I have seen the dolby article, but sometimes the real world experience is different.
I will probably try varying heights, I just didn.t want to have loads of holes to fill up.
I will wait till tomorrow to try out, 2 foot above just seems to high. maybe thats because I have been used to having floorstanders as rears.
buns
and of course different designs and different rooms will tend to suit different height configs....
ad
Supra
Right it looks like 2- 2.5 feet above ear level seems to be a popular choice. Now is the measured from the tweeter?
sorry for the extra questions, just trying to get it aall right.
thanks for the replies so far
:thumbsup:
ahh
Unless your speakers have really large tweeters, I don't think a few inches higher or lower is going to make any difference.
buns
yeah, i would consider all measurements to be taken from a tweeter since it is the part producing the most directional sounds
ad
Supra
Right 2 feet(60cm) from tweeter to ear it is. Now to go and set it up, more mess.
Thanks for all your help peeps:thumbsup:
Supra
All done, wow, what a differnce.
I wish I had done this sooner, wall mounted does give a more enveloping sound, next weekend I will try 6.1 and 7.1 with the kefs running the rear channels, until I get hold of another snt or two:thumbsup:
Now I will stop and have :beer: , then re set all the speakers.
Thanks again for all the help :smashin:
Similar threads
