What is the easiest way to get component out from a regular video card?
Discussion in 'Desktop & Laptop Computers Forum' started by GothMogh, Dec 23, 2003.
  1. GothMogh
    GothMogh
    Dec 23, 2003
    Hi All,
    I'm looking into setting up an HCPC, but due to distance between projector and HCP, I would rather not go with DVI (12m). (it also happens to be a fact that I already have a 12m component cable, that I'd rather reuse.. :p )
    I am looking to feed my Z2 with a 720p signal over component input. As there are obviously very little cards that have component output standard onboard, I was wondering what the easiest way is to go from a VGA output to component?
    Can this be done by a simple breakout cable? Is a converter required? Are there any other simpler solutions to connect them?
    Cheers and thx!
    GothMogh
  2. Piya
    Piya
    Feb 6, 2002
    Leeds
    I have no choice but to get a transcoder to use with my JVC component inputs.
    Regards
    Piya
