What % is the drop in quality on my panny will going from a HCPC to the new Philips
Discussion in 'Projectors, Screens & Video Processors' started by brad123, Jul 3, 2002.
  1. brad123
    brad123
    Jan 29, 2002
    3,833
    68
    West Yorkshire
    +62
    The new pHilips with PAL and NTSC progressive scan thats on sale at Hifizone. What percentage in picture quality drop will it be from a HCPC to this new philips.
    My heart says HCPC but my head says this new Philips.Just noticed the Philips DVD-Q50 as well does progressive in pal and ntsc but it doesnt do sacd, whats sacd, will i need it.
    ASre these 2 players virtually the same apart from the sacd on the more expensive one.
  2. Guest
    If you use a transcoder ( component to rgb converter), the difference will be very small and you don't have the hassle of a PC.
    Scott
  3. Guest
    Even if you don't use a transcoder and use the component input the difference is very small as we proved last weekend at Shocks mini shootout. If you can afford it I'd go for the 962SA as it's fantastic and is better for CD playback and of course has Super Audio CD which sounds fantastic.
    Andy
  4. Samir
    Samir
    I'm with Andy, after seeing the 962SA at the shootout via component vs HCPC I feel that HCPC aren't worth the extra headf**k when you consider that the step up is not as big as I was lead to believe.IMP
    Also is the Q50 an inport model as the UK one doesn't do pro scan
    I must admit that I do like the look of the Q50 over the 962SA
    Samir:)
  5. brad123
    brad123
    Jan 29, 2002
    3,833
    68
    West Yorkshire
    +62
    IM TEMPTED TO GO FOR THE PHILIPS Q50.
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,800
    87
    Newcastle
    +118
    Still seems to be conflicting info about these players. Do thet do prog scan or not?
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    There are UK companies claiming PS from the Q50. There claims are false. Only available from R3 as stated above. Be warned.
    They are less than friendly when challenged.....
  8. brad123
    brad123
    Jan 29, 2002
    3,833
    68
    West Yorkshire
    +62
    both these machines are NTSC and PAL progressive if ordered from hivizone.
  9. brad123
    brad123
    Jan 29, 2002
    3,833
    68
    West Yorkshire
    +62
    I sent an email to hivizone asking about the Q50 and 962 and heres the reply.
    Hi there,
    im interested in the 2 Philips DVD players you have that do PAL and NTSC
    progressive scan. The Philips Q50 and the Philips 962SA.
    Firstly im not bothered about SACD and the player is to go into the Panasonic PT AE100 projector.
    Is there a difference in picture quality between these 2 players as like I say the SACD is something im not bothered about.
    *There is no visible difference in picture quality between the 2 DVD players. *
    Ive heard bad things about problems with the Q50 has this been resolved now with new firmware etc. If theres no difference in picture quality id go for the Q50 as ive heard its the same as the 962sa but without SACD playback..correct??? And you can definalty say BOTH these players do NTSC and PAL progressive scan.
    *The problems of Q50 have been solved after the firmware upgrade is released.
    If you do not need SACD playback, Q50 should be your choice. Both DVD players can output NTSC and PAL progressive scan.
    We look forward to your order! *
    So if im not bothered about SACD the Q50 is worth it.
  10. chaddlad
    chaddlad
    Jun 24, 2002
    manchester
    has everybody forgot skyworth or nintaus dvd players , i have been looking at what to buy myself and i had this at the top of my list , am i just better of going for the philips or something the same from over here.
    chaddlad
