I have had such a thrilling day today, messing with my toys and not getting anywhere.
This has resulted in the usual response, throw some money at it!
I'm not sure what I'm looking for as I am confused.
I have a PC. It is connected to a WAG54G (An ADSL Gateway with 4 ports) This device keeps the link to the net up and allows me to share the link wirelessly with a work lap top. It also after not inconsiderable effort links wirelessly to two Squeezeboxes two floors below.
The connection allows me to work in the garden but is a bit slow. The connection to the SBs is pretty reliable but could be improved.
What to buy?
I thought a range extender but, today's issues highlight that the Linksys one available does not work with my existing kit. I considered a high gain arial but they are not compatible with the WAG54G.
So it looks like I need to replace the WAG, but what with?
1. WAG200G (Hopefully compatible with the range extender.
2. WRT54G I dont understand the difference between this and the WAG54G so dont want to buy in haste.
3. High gain arial
http://www-uk.linksys.com/servlet/S...260558&pagename=Linksys/Common/VisitorWrapper
Thoughts?
What to buy?
3. High gain arial
Thoughts?
