what is the difference between pw7 and pw8 ??
NGD Boy
Just wondered what was the difference... could someone please point me as to why one has the advantage over the other, hopefully I will be buying soon and want to know why the 8 is better than the 7..
cheers
Carl
NGD Boy
If I'm only going to use it for sky and dvd player will it matter which one I go for ?
thanks
Carl
ps... is there a fan in the 7 and not a fan in the 8.... is the 7 noisy ?
NGD Boy
So basically, I only need to go for the PWD8 if I had or wanted sky HD.... there is quite a difference between the 2 screens pricewise....£1199 for PWD8 and £899 for PWD7... better off with the 7, then I can use the difference for some JStech boxes... sound ok ?
NGD Boy
Which one PWD7... richersounds... according their site.
Piers
Should also have said the 7 doesn't accept component over the VGA port. Important if you are thinking of using a JS Tech RGB to YUV converter.
hornydragon
Not just sky HD more importantly Ps3, HD-DVD and Blu-ray will potentially all require 50Hz HD digital (DVi or HDMI inputs) and that just what we know about PWD8 is now £1080 delivered from AV-sales!
NGD Boy
Does that still include ped stand/wall bracket and delivery ?
