What is the difference between a TUCT20 and TUCT30?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by KTF, Jan 17, 2004.
  1. KTF
    KTF
    A friend of mine is offering me his Panasonic TUCT20 STB but I cant tell if it has audio out (or not). On the Panasonic website, the TUCT20 seems to have text and EPG whilst the TUCT30 has the audio out yet both are the same price.
    On the argos website:
    http://www.argos.co.uk/webapp/wcs/s...0001&langId=-1&catalogId=1751&productId=87117
    They say that if you order a TCUT20 then you might get a TCUT30 instead so does this mean that they are actually the same? If they are then why are there two different models?
    :confused:
  2. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    The TUC20 is not longer supported by Panasonic, it will never get any more updates for e.g 7 day EPG etc etc...
    The TUC30 is supported by Panasonic (at the moment)...
  3. CARLOS
    CARLOS
    Feb 11, 2001
    6,455
    WEST MIDLANDS
    +1,412
    TUCT20 has only one scart, TUCT30 has two !
