What is the best possible 26 inch lcd tv for gaming.
RockySpieler
A dell 2407 moved 2" closer to your nose.........:D
I am serious, for PC gaming 4:3 ratio do still exist, so there is a benefit in a 1920x1200 resolution (Both 1600x1200, and 1920x1080 capable) screen. The dell 2407 was an unbelievable £407 over easter.
However if by gaming you mean PS3 or X360 then a 26" LCD TV (1366x768) would suffice.
T
tricky1974
I've 26LXD600 its got loads of connections I've a xbox 360+component,ps3+HDMI,xbox+RGB scart,gamecube+RGB scart and a dvd player HDMI hooked to mine and i've still a spare scart and vga connections to use yet?
bluevortex
I have a Sony Bravia KDL26S2030U and it's great on the Xbox360 and PS3.
I also have this LCD and play 360 on it often. Its a cracking little TV and can be had fairly cheap now. You do need to get the settings right on it though - but that goes for any display i guess.
