What is the best MCE compatible tuner that accepts a sky signal?
Discussion in 'Microsoft Windows' started by sunlink, Aug 14, 2005.
  1. sunlink
    sunlink
    Any advice gratefully recived.
    Steve :thumbsup:
  2. Spacecat
    Spacecat
    Apr 1, 2001
    2,897
    London
    +583
    iam assuming you mean via a SKY STB?
    best method is using a a Scart to Svideo convertor (maplins £35) sent into a 550PRo card via the svideo input.
    Sapphire do one pretty cheap and its the best around , others may disagree.
    also consider a hauppage 150 but im not sure if it can accept an Svideo signal.
    I use a 550 pro in the set up as outlined from a Telest STB and the picture quality is superb.
  3. sunlink
    sunlink
    Thanks for the advice. I will look into it.
    Steve :)
  4. OneEleven
    OneEleven
    the hauppauge 150 can accept s-video in
  5. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    I use the hauppage pvr150 (roughly 40 quid) fed via svideo from my sky+ box, after tweaking and messing with a few registry settings the picture is very nearly as good as the live feed.
  6. crazyal
    crazyal
    Feb 14, 2005
    439
    Cov
    +57
    Would those registry tweaks work on a PVR-350 aswell? If so, could you let me know what they are please as they may help with my current problem.
  7. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
