what is the best interconnect to connect a preamp, power amp, processor together.
Discussion in 'Cables & Switches' started by mgh0001, Nov 4, 2005.
  1. mgh0001
    mgh0001
    Sep 5, 2005
    498
    trafford, manchester
    +3
    which is the best interconnect when connecting a processor to a pre amp then the pre amp to a power amp.
    i was thinking about using the van den hul "MC gold" or the "first ultimate mkII" would that be the best option.
    any ideas?.
    cheers, mike
  2. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    Maybe a good idea to borrow a few different makes of cable and see what you like the sound of best. Then gradually work up their range, see what you like.
    I think the general rule is spend something like 10% of the cost of your kit on cables, but I am somewhat over that budget just on the one cable, and another to go yet.
    If you don't hear any difference you are lucky and can go for a nice cheap one.
