What is the best (cheapest) place to buy ARCAM P7, AV8 and DV27
Discussion in 'AV Receivers & Amplifiers' started by URI, Oct 6, 2003.
Tags:
  1. URI
    URI
    as in the subject line, I am from Poland and wanted to order the stuff and visit UK to collect it, is it better to buy in a dot.com or brick&mortar?? Which dealer has the best prices??
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    i dont know you will be able to buy in a dot com..... i cant claim ever to have seen these machines online. The best you can really do is find a good dealer and haggle a bit. Alternatively you could look up John Dawson from arcam (he is a member on here) and see what he could suggest for your situation.
    all the best
    ad
  3. spiderv6
    spiderv6
    Dec 12, 2002
    138
    16
    Uri, on-line availability of Arcam gear is generally non-existent (you will now see 20 posts proving me wrong....). Anyway, with the kit you are buying I would want to see into their eyes before I parted with the cash!
    Generally you will be able to get a 10% discount without a problem. Given the amount you plan to spend I would be looking for at least 15% - depends how persuasive you are! ;)
  4. rags
    rags
    Apr 13, 2003
    4,087
    London
    +304
    You should target 15% or so. Also dont forget that as your exporting the goods, you dont pay VAT. Your retailer should give you a completed VAT refund form and you should be able to collect the refund as cash from the airport on your way back.
  5. kryten
    kryten
    Apr 9, 2003
    532
    Swindon
    +14
    I can just image turning up and trying to get your P7 on as hand luggage :) (I certainly wouldn't want it to go in a suitcase, given the 'care' with which they are treated!)
    If you want to get the VAT back, you'll need to come before you join the eu at the end of the year!
  6. rags
    rags
    Apr 13, 2003
    4,087
    London
    +304
    You just check in the box as luggage. Do you really think that any most courier firms treat parcels any better than airport baggage handlers ? I doubt it. If you exporting to Poland you have little choice in the matter. Just make sure the packaging is good and mark it up everywhere as fragile (slight chance that it may help!). If you dont need the boxes take the AV8 and DVD player as hand luggage.
  7. Richard Barham
    Richard Barham
    You are probably already aware that the P7 package is HEAVY, so you may need to make allowance for that when travelling.
    It is also interesting to note that the RRP of the full package is £7.1k. I wonder where that figure came from...
  8. URI
    URI
    If I get 15% off and VAT I would save GBP2000. The downsides are:
    1 I have to bother with taking the stuff back
    2.There is a risk of damaging any of the units (low though)
    3. There is a risk of being stopped at the Polish border and having to pay duty and VAT (the saving would be gone, this is very small risk as for the last few years I was never stopped at the border)
    4. The biggest problem is that the warranty would be not valid in Poland
    DO you guys think it is worth it?? What do you mean when you say that packaging is have ( I would like to fold it and check in bags). How often the units go wrong??
  9. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Uri,
    Why would your warranty not be valid in Poland?
    Arcam warranties are transferable worldwide, that is one of the reasons I bought mine, as shortly I'm moving to Australia.
    Regards
    John
  10. URI
    URI
    The Polish distributor refuses to service anything bought outside of Poland!!!!!! I know Arcam says that the warranty should be valid but the Polish distributor says NO :( :mad: :(
  11. Richard Barham
    Richard Barham
    The weight of the P7 in its box is 35kg.
  12. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Uri,
    Give Arcam a call re the Polish distributers refusal to service anything from outside Poland, I'm sure that they would be interested.
    Good luck
    John
  13. Mogli
    Mogli
    Feb 25, 2003
    764
    43
    +124
    True but i am not sure how he would arrange insurance? I was thinking of bringing back some kit from the uk in the same manner at one stage but after finding out that the Airline wouldnt be liable for the full value of the goods if missing or for any damage etc i decided against it. Could you get your travel insurance to cover that?
