What is the best AV mode for listening music??
Discussion in 'AV Receivers & Amplifiers' started by ciber, Jan 5, 2004.
  1. ciber
    ciber
    my onkyo 601 AV receiver has 5.1 setup, with following av mode:
    ALL Channel stereo
    DSP studio mix
    DSP unplug
    DSP orchestra
    Dolby Processing II Music
    Neo music
    stereo
    direct
    Which is the best for CD music
  2. Kramer
    Kramer
    Direct.
    Bypasses internal processing.
    :smoke:
  3. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    I also use direct for 2 channel music but with the sub on.
  4. Branxx
    Branxx
    Nov 1, 2000
    801
    London, UK
    If your main left and right speakers are not full range than you cannot really use direct mode as there will be no bass management.
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    In which case stereo would be better. Ultimately it's your choice though - listen to them all and see what happens. I know some people who swear blind by 5-channel stereo (or the equivalent) and my brother likes PL2 for some reason.
  6. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    PLII is a must for TV and radio, also for most CD listening... :smashin:
    Now, while I had my Onkyo 787 + Arcam DV88, it would sound much better direct, using the DVD´s DACs, and, as I had a REL sub, I could still use the sub´s high-level connection, plus the low-level for surround... :rolleyes:
    With a good processor, I always use DPLII... :smoke:
  7. kiddi
    kiddi
    OK, I have the sony str-db790. What surround mode would you use to listen to music. The dolby pro locic II music or DTS Neo:6 music modes?
    I've been trying them out and feel that the DTS mode is slighly more "forward" and aggressive. So I've been using that. What are your preferences?
  8. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
    ciber,
    Just want to congratulate you to owning a Onkyo 601!!!
    I have tried to promote Onkyo here as their x01 series is very good (not only a one brand fan, and if their series isn't good I wouldn't recommend them), but I don't think potential buyers have taken the step as the brand is not that known here as it is in other countries.
    Maybe you could give some opinions at the Yamaha DSPAS640ES or MarantzSR5400 thread? superdons thread
    I like my CSII mode a lot, but depending on the cd or dvd 2channel DPLII is also used, but my Neo:6 is rarely used.
    An excellent review of 601 here
    audioholics He kind of liked the All ST mode on the remote. In terms of the pseudo 5.1 modes, he reckons it depends on which cd/tv programs etc you are watching, there is no one single mode that is best for everything.
    Wasabi
  9. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I tried NEO:6, it would be very convenient to have different settings for center for different sources, but I didn´t like it a bit... :thumbsdow
  10. jameslindsey
    jameslindsey
    May 21, 2003
    410
    +20
    Technically the answer is listen to the music in the format that it was mastered for. IE 2 channel for normal CD. You may find Direct cleaner and more detailed than Stereo as there are no electronics in the way of the signal.
    In Practice listen to it in whichever mode sounds best to you.
    You may also find that internal processing of stereo and output via analogue to your Amp sounds more pleasing than digital output from the DVD/CD and the Amp doing the processing. Depends on the DACs in each device, but worth a try.
    Sorry to confuse the situation.
