What is the aspect ratio of T2 UE?
Discussion in 'Movie Forum' started by eros, Sep 1, 2000.
  1. eros
    eros
    If it is 2.35:1 then I am not going to buy it, as T2 was filmed with a format called super 35 which is close to the 16:9 ratio. This means the 4:3 ratio would give me more of the original picture than the 2.35:1.
  2. Guest
    Super 35 actually has a ratio of about 1.66:1.
    A widescreen frame of 2.35:1 is taken out of this as is a 4:3 frame.
    The director intended 2.35:1 to be the correct ratio.
    Framing can look odd if other ratios are used and may introduce dead space.
    4:3 would give more top and bottom but would lose at the sides due to the f#cked up way Super 35 works.
  3. European
    European
    "If it is 2.35:1 then I am not going to buy it, as T2 was filmed with a format called super 35 which is close to the 16:9 ratio. This means the 4:3 ratio would give me more of the original picture than the 2.35:1."
    . . . sigh . . .
    ! [​IMG] !
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,554
    Somewhere in South Yorkshire
    +6,057
    Sigh! too.
    There is only one way to do HOME CINEMA (note the words there) and that is as close as possible to a real CINEMA. Regardless of what techniques were used for shooting the film, if it was shown at 21:9 at the cinema, then 21:9 is the ONLY way it should be seen at home.
    If you still believe that the earth is flat, just don't buy it. Go buy the fullscreen VHS version instead.
    You should not drink and bake.....
