What is the absolute best sub 50" Plasma?
Discussion in 'Plasma TVs Forum' started by akki007, Feb 9, 2009.
  1. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    As the title suggests. Money is no object, has to be sub 50". These are the only constraints. What would you suggest?
  2. Kev12
    Kev12
    Feb 7, 2002
    4,244
    Leeds
    +454
    If you can source a Pioneer 428XD, very scarce now, I'd say that.
    Do you mean 50" is too big? If you include 50" theres also the KRP 500A/M.
  3. bladedripper
    bladedripper
    Nov 26, 2007
    5,074
    Birmingham
    +1,529
    Wait for the new panasonics.:smashin:
  4. Coffin
    Coffin
    Mar 20, 2008
    11,576
    +5,184
    Why does it have to be smaller than 50"? :)
  5. rewerb
    rewerb
    Feb 29, 2008
    4,448
    +639
    The new Panasonic Z-range
    Z10E series
    [​IMG]DVB-T MPEG2/4 VGA (PC input) DVB-C MPEG2/4 Viera Cast + DNLA 1080p resolution THX certified display Neo-PDPDigital Cinema Color 1080p motion resolution 24p cinematic playback 1" thick (2,54 cm) x.y. color 600 Hz sub field drive Deep colour - (IFC Pro) V-Audio (surround) 40.000:1 native contrast AR Filter 4 HMDI inputs BBE ViVA HD3D sound SD card readerPanel lifetime: 100.000 timer- (JPEG + AVCHD) RF remote control Wireless design- wireless HD (10 m)
    Models: TX-P46Z10E, TX-P54Z10E
