What is Servo
Discussion in 'Subwoofers' started by Shin Akuma, Jun 16, 2005.
  1. Shin Akuma
    Shin Akuma
    Dec 29, 2004
    2,878
    71
    +90
    I have seen subwoofers with servo control but Never used one with servo control, what is servo control, how much it effects the LF effect. Does it only comes with top notch subwoofer.
  2. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    924
    46
    +114
    this will explain things to you. :)
  3. Shin Akuma
    Shin Akuma
    Dec 29, 2004
    2,878
    71
    +90
    thanks mate.
    can someone name few servo controlled subs. pls
  4. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    660
    Newcastle upon Tyne
    +20
    HGS and DD range from Velodyne.
    There is a video interview of Bruce Hall on the secrets site and he explains servo quite nicely.
    Martin
  5. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    924
    46
    +114
    The other obvious one, is the Paradigm Servo-15.
  6. russraff
    russraff
    Aug 1, 2000
    2,415
    Newcastle
    +63
    Jamo also make servo controlled subs - the D6SUB and D7SUB are servo controlled.
    Russell
  7. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    Two more I can think of:
    Velodyne CHT15 and the new 15R
    Mackie HRS120
  8. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    924
    46
    +114
    Although the CHT-15 uses some form of motional feedback system, I don't think it's considered a servo in the strictest sense.
    I don't know about the newer CHT-R range though. :)
  9. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    What's the definition of a servo?
  10. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    924
    46
    +114
    A servo uses an accelerometer attached to the voice coil of the speaker's drive unit to measure the cone's movement and compare it to the input signal.
    I'm pretty sure the Velodyne CHT range uses a current sensing feedback system, which works by comparing the current generated by the voice coil, with that of the current being fed to the driver from the amplifier.
    Servo technology is more accurate and more expensive to employ.
  11. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    I thought the CHT15 had an accelerometer, but a quick google search tells me it doesn't. So you're right. :)
  12. FeisalK
    FeisalK
    Jun 9, 2005
    375
    KL
    +21
    don't forget this one
    [​IMG]
    doesn't look like much tho..
