What is SDI?
Discussion in 'Blu-ray & DVD Players & Recorders' started by robfitzp, Jan 18, 2003.
  1. robfitzp
    robfitzp
    Dec 12, 2002
    1,162
    38
    Bristol
    +20
    What is an SDI connection - is it superior to DVI?
    Rob.
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Hi Rob,
    SDI stands for serial digital interface and is a single wire (coaxial)connection supporting interlaced video running at 270MHz. It is normally used in broadcast studios and the like.
    DVI stands for Digital Visual Interface and is a parallel connection using 4 twisted pairs (RGB and clock) running on a special connector. It can support a wide range of standards, well beyond XGA IIRC, but the minimum is 480p or 576p.
    Both of these have comparable quality but are not copy protected and are thus absolutely not allowed on DVD players, set top boxes etc. It is possible to get aftermarket mods with the usual caveats of invalidating the original warranty and so on.
    DVI does have a copy protected version, DVI/HDCP, and this is about to become legal for DVD players and STBs, indeed it is soon to be mandatory for US HDTV STBs. This will drive the market in a big way. However since the HDCP licence does not permit you to come out of digital back to analogue (even composite) video ever again you need a display equipped with a DVI/HDCP input. These are just starting to appear on the market but note displays equipped with DVI but without HDCP decryption are useless in this context.
    HDMI (High Definition Multimedia Interface) is mostly a superset of DVI/HDCP and also supports interlaced video, YUV colour space and audio (this year SPDIF, next year 8 x 192kHz/24 bit). Displays will incorporate this from late 2003. I predict this will be the worldwide standard in the future. For video purposes DVI/HDCP and HDMI will work together.
    Incidentally there are moves afoot in the world of copy protection to eliminate all analogue video interfaces on source components within say 5 years, with the exception of composite video. So IMO you should start to think very carefully if you are considering something like a new projector - make sure it has a DVI/HDCP input or can be retrofitted with one.
    HTH.
    John Dawson (Arcam)
  3. lmccauley
    lmccauley
    Oct 24, 2000
    3,302
    Newcastle
    +212
    Interesting stuff. Presumably DVD player manufacturers are looking seriously at DVI/HDCP or HDMI outputs for late 2003 onwards...
    Specifically (and I realise this is probably something you can't answer yet), when one or the other standards are ratified (by whoever needs to do it), will it be possible to add one of these outputs to a DV89 or DV27 player?
    Cheers,
    Liam
  4. rauer
    rauer
    Feb 17, 2001
    425
    +7
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    :blush:
    Pity my original post is now number three!
