What is RGB
Discussion in 'General TV Discussions Forum' started by ayubars, May 11, 2004.
  1. ayubars
    ayubars
    Oct 29, 2003
    91
    LONDON-UK
    Hi guys,
    soory about this. But what exactly is RGB? I have a JVC 100Hz TV and never found out what exactly this is. Is it another AV socket at the back? Is it a place to connect the DVD player to?
    thanks guys...
  2. Paul Atreides
    Paul Atreides
    RGB is a type of video signal that only goes through a scart plug.
    It's very good quality and you should use it for DVD unless you have
    component inputs on your TV, as that is the best you can get.
  3. ayubars
    ayubars
    Oct 29, 2003
    91
    LONDON-UK
    HI,
    How do i know if i have components inputs? Is it those Yellow, white and Red inputs on the side?
  4. ayubars
    ayubars
    Oct 29, 2003
    91
    LONDON-UK
    Is this the same as composite input?
  5. ayubars
    ayubars
    Oct 29, 2003
    91
    LONDON-UK
    My TV is : JVC AV-28X37HKE 28in widescreen Nicam TV. Do you think i have component inputs?
  6. GaryB
    GaryB
    Nov 12, 2002
    5,393
    St Albans
    +1,303
    The AV-28X37 does not have component inputs. It has RGB capability on External 1 and External 2 (two of the three SCART sockets on the rear). To use RGB, make sure you use a fully wired SCART cable and set the output of your DVD player to RGB. The TV should automatically detect that it is receiving an RGB signal and switch to it.
  7. ayubars
    ayubars
    Oct 29, 2003
    91
    LONDON-UK
    Thanks for the Info GarryB.
    Im currently using a normal black color scart lead. Just some cheapy one. But i can see the picture quite fine. My DVD player is the all in one with a VCR alwell. I'll have a look tonight to see if there is an optoin for RGB in the DVD player mode.
    BTW: Is my scart lead ok? How do i know if it's fully wired?
  8. Paul Atreides
    Paul Atreides
    You can usually tell by looking at the plug and seeing if it has all the pins present.
    Also the cable should be fairly thick, if it's really thin it won't be fully wired.
  9. Paul Atreides
    Paul Atreides
    No.
    Composite - Worst
    Component - Best
    Ironically they sound the same.
