What is RG 59 / RG 6
Discussion in 'Home Cinema Building DIY' started by sticker, Jun 21, 2003.
  1. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Can anyone tell me what RG 59 / RG 6 is and where to buy it?
    Regards
    John
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    They are Coaxial cable specifications. Your satellite/cable/TV coax will be a type of RG59. RG6 is a slightly thicker, more rigid type.
    You can buy it from the likes of Farnell, CPC, RS Components, Maplin. However what you need to decide on first is it's use, as this will better determine the specific cable manufacturer and type you should be looking at.
  3. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Thanks Groundy for your reply.
    The reason I ask is that I've seen a few posts by Nic Rhodes concerning this relating to subwoofer cable
  4. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Most Sub cables are coaxial based. As long as you pick a type with good electrical characteristics & proper shielding, it can be a fantastic performer in a variety of different applications.
  5. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Could I use Van Damme starquad microphone cable for sub cable?
    Sorry to be thicky but I'm unsure how you determine what is coax!
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Co-ax is such a cable that has a central core with a shield or some other conductor all around it, in a circle (if seen as a cross section).
    Such like the afore mentioned aerial cable.
    I use star-quad for my sub and it sounds pretty damn good to me. You do not need to use co-ax for a sub, provided that the signal cable is good it will work well. All down to your ears at the end of the day.
  7. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Thanks guys
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    The beauty of Coax in sub cacles is it is cheap! 50p will net you a fine cable suitable for the job. The 75 ohm CI etc are irrelevant at audio frequencies but vital for digital / video.
  9. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    I like the words "cheap" and "fine" in relation to anything AV:devil: .......thanks for everyones input and thanks for putting up with all the dumb questions I've been asking in this section.
    Just upgraded my proc/amp/dvd/sub/speakers and trying to get full value from them without spending an arm and a leg...........one leg and an arm has gone on buying the electronics, I can't afford to lose the others on the cable :)
    Regards
    John
