What is Gale speaker cable like?
Discussion in 'Home Cinema Speakers' started by blue_harvester, Aug 14, 2003.
  1. blue_harvester
    blue_harvester
    Jul 28, 2003
    108
    16
    Belfast, Northern Ireland
    Title says it all.
    Setup:
    Marantz SR4300
    Eltax Liberty 5+
    Eltax Liberty Centre
    My local RS has only the Gale stuff and I was wondering whether it would be sufficient. I want to Bi-wire the front left and right. Should I order the QED Original cable of the RS website? It's £2.50 per metre although I don't see any bi-wire stuff, do I just order twice as much of the oridinary stuff to bi-wire?
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Get the Gale biwire. It's plenty for your needs. Actually I prefer working with the Gale cable - it's more flexible than the QED stuff.
  3. Dazed
    Dazed
    I'm not much of an expert but I've used lots of Gale stuff in the past - I currently use it for the speakers in my kitchen - sounds fine to me
  4. wookie
    wookie
    Conductive
  5. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Don't want to put you off but mine went green.The shark stuff from maplins is far better.
  6. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    I use it, it's cheap and does the job for me, for now...best to buy more that you need, then trim about an inch off it say every 6-8 weeks...
  7. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
  8. joshua_bond
    joshua_bond
    Jun 25, 2002
    354
    +16
    Blue_havester,
    Like you, I have 5+ (with Yam630se) and connected to Gale XL 315 (Richer sound).
    For smaller rears like 1+ and 3+ consider XL 189 - which I use
    My system is not bi-wire so I can't say. But in terms of quality, you can't go round. Mind you you could shop around for slight better cables for short runs (i.e. less than 10feet).
  9. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
