What is Dual Channel memory?
Discussion in 'Computer Components' started by Mark Ward, Sep 7, 2003.
  1. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    SB61 Shuttle can use:- Two DDR Slots, support DDR 266/333/400 and Dual Channel DDR
    Checking the Crucial site I can't find any Dual Channel DDR memory.
    DDR PC3200 • CL=3 • Unbuffered • Non-parity • 5ns • 2.5V • 64Meg x 64
    or
    DDR PC3200 • CL=3 • Unbuffered • ECC • 5ns • 2.5V • 64Meg x 72
    in 512Mb.
    Will "Dual Channel" memory give me any performance advantage?
    Cheers,
    Mark.
  2. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +215
    Dual Channel refers to how the motherboard access the RAM, and not the RAM itself.
    You just use normal DDR RAM, and with a pair of matched sticks, you can configure the mobo to run in Dual Channel mode.
    This increases memory bandwidth, so should give you a bit of a boost in memory intensive applications.
  3. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    if you get two separate sticks of memory (need to be identical AFAIK) then dual channel allows you to write/read to/from both simultaneously giving a nice performance boost - think of it as a bit like raid striping but with memory.
    HTH
    owain
  4. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    2 excellent replies at the same time, thank you:)
    Mark.
