What is best 36" TV
Discussion in 'Televisions' started by Steve N, Mar 20, 2005.
  1. Steve N
    Steve N
    Feb 3, 2005
    10,371
    Peterborough
    +1,786
    After reading the problem threads on the Pannys (which I was thinking of buying) But frightened off now.
    I was wondering what sets other users have been pleased with and would reccomend
    Is there an ideal set out there - I want superb picture, Not worried about sound as will use system. Also want plenty of inputs (RGB,S-Video + component)
  2. billystevo
    billystevo
    Mar 13, 2005
    53
    9
    Everyone has there own favorite manufacturer,mine being Panasonic. You will have to to see for yourself what you can get for £X you want to spend. Ive just bought a TX-36 PL 32 as i don't need the Dolby sound stuff as i have an Yamaha amp. What i have done this time is get a 5 year repair warranty for £178 as i think the quality of av equipment is hit and miss nowadays.I'm happy with my TV , good hunting and let us know what you get in the end. :D
  3. fdxd
    fdxd
    The panny pd50 is probably the overall best. Its expensive however.
  4. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Steve,
    Please don't be put off by a few rogue Panny's!
    I bet there are a hundred (possibly thousand) satisfied Panny owners for every problem on the Forum.
    If you're after a manufacturer that has a 100% fault/reliability record then you'll never buy another TV!
    Panasonic, Toshiba and Sony are all highly rated (but not perfect).
    Perhaps it's more important to go to a supplier with a good Customer Service policy.
    Good luck. :smashin:
