what is a scaler?
Discussion in 'Desktop & Laptop Computers Forum' started by taimur, Feb 16, 2003.
  1. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    Can someone tell me what a scaler is?
    Taimur
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    In very simple terms it takes regular usually interlaced video or film material and upscales it to a higher usually progessive resolution. My my case I take 720x480i (R1 DVDs) and scale them up to 1440x960p. While upscalling doesn't add any real detail it does make the picture look much better especially on a CRT projector. With digital projectors there is much to gain by scalling to its native resolution.
  3. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    thanks - so am I right in thinking that a PC DVD drive reads the information in the DVD as its been encoded (whatever that may be) and scles it to the output of the VGA card and this is one of the benefits of a HCPC system over a DVD drive?
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Nearly, the VGA card is the bit that does the scaling and by the scaling occuring in the PC all the display device has to do is display.
  5. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    I see... thanks
  6. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    Does this mean a PC DVD drive outputs a standard resolution of 720x480i?
  7. Kramer
    Kramer
    No.
    A PC DVD drive outputs only a digital data stream. Bytes - 1s & 0s.
    The DVD player software (or any other pertinent software) takes this data & decodes/utilises it accordingly.
    But the data stream has "tags" or "flags" which tell the software whatever format is on the DVD.
    I think I'm right there, but, as always, explaining is my problem :blush:
