What is a reasonable price for a scart cable
Discussion in 'Cables & Switches' started by Sharpy14, Sep 1, 2005.
  1. Sharpy14
    Sharpy14
    I need to link a sky digibox to a plasma, the hdmi socket will be used for the DVD player so assume the best route is a scart RGB cable.
    QED and Ixos seem to be the good makes, but prices seems to run from £20 to around £80 (I need 3 metres).
    I don't really want to spend more than about £40, any recommendations?
  2. bri.s
    bri.s
    Aug 6, 2005
    281
    28
    Livingston
    +28
    I picked up a 3 metre IXOS XHT601 for £32 which included delivery on ebay last week and it has made a big difference from a standard scart and I saved a few quid. I could have had a few different ones from ebay there is plenty to choose from have a look.
  3. oh aye
    oh aye
    Have a look at tvcables.co.uk Thor RGB scart 3 metre version about £25 delivered i have 3 of these cables (the standard 1.5 metre version) and i think they are excellent.
  4. Myer
    Myer
    When people refer to RGB scart, do they mean only RGB pins connected, therefore picture only and no sound, or are they refering to a fully wired scart, carrying picture and sound.
  5. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    £2.50 is about the max you should spend on a SCART.
