what is a optical lead
Discussion in 'Cables & Switches' started by jtfab75, Aug 25, 2004.
  1. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    recently got a panasonic e55 dvd recorder and a pioneer vcx-100 amp.they both come with digital optical connections.
    what does the optical lead do ? does it carry sound/picture or both.
    do i need to need the phono leads to attach to the panny and pioneer ??
    thanks
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    its a type of audio connection which carries digital audio (in this case from the dvd player to the amp). It has a connector which is very different to all the others on AV equipment. Don't waste money buying an expensive one, just go for a cheapy (if it didn't come in the box with the DVD)
    Owain
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The optical connection only carries audio, so you need some additional connection for the video, either via the amp or directly to the TV. You don't need any phono leads.
