What is a monoblock?
Discussion in 'AV Receivers & Amplifiers' started by John Watts, Jun 23, 2002.
  1. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    Hi folks,im sorry for what may be a dumb question for many of you but can you tell me exactly what a monoblock is i have seen them advertised and heard the term used quite alot but im not really sure what they are.
    Thanks for your help,John.:confused:
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    It's a power amp that only drives one single speaker.
    So of course you would require two for a stereo set up.
  3. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    Thanks Alanrob.
    So in theory you could have a processor and as many monoblocks as you need for either 5.1 or 7.1 surround sound or is it only for stereo setups.
    Also am i to assume that 2 monoblocks work better that most single box stereo amps?
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Yes, one monoblock = one channel of amplification. Of course you can then have 5 or 7 or more, as much as you desire or your processor supports in numbers of channels.
    Just remember that each block has it's own power supply, so cabling will be very messy.
    You mean compared to a 2-channel power amp? That may depend on the make and model I guess (of both, monoblock and power amp).
