What is a DVDFLR worth?
Discussion in 'TAG McLaren Audio Owners' Forum' started by ChrisNic, Sep 5, 2005.
  1. ChrisNic
    ChrisNic
    May 11, 2003
    1,915
    63
    Thame
    +109
    I seem to gather that standard DVDFLR's fetch around £1000, how much extra is one with the PSM module worth?
  2. Spen69
    Spen69
    Lintone had them up for £1,300 but they were gone before you could call at that price. I'm sure that Hifibitz had them kicking about for £1,600 at the very end.
    Hope that helps.
    Regards - Spencer
  3. ChrisNic
    ChrisNic
    May 11, 2003
    1,915
    63
    Thame
    +109
    Thanks for that, I spent quite a while earlier looking for the price that they went for new at the end.
    Cant be bad if I end up with a DP and an FLR for about 3k (although it does sound like a lot when I type it!). Just need a bryston now......
