What is 1:1 pixel mapping?
Discussion in 'Projectors, Screens & Video Processors' started by Clint C, Aug 8, 2003.
  1. Clint C
    Clint C
    Dec 10, 2002
    420
    Wiltshire UK
    +4
    I've seen it mentioned a lot around these forums but can't find any reference as to what it actually is. Is it simply DVI out of a pc to the DVI of a pj? Scuse my ignorance...
  2. vulkan75
    vulkan75
    Hi.basically Its when your source ,dvd, hcpc ,etc matches perfectly the resolution of your display device (projector).
    I think thats right....
  3. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
  4. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Neil,
    One more link for the FAQ, methinks........... Nice find.
    All the best,
    Sean.
  5. Clint C
    Clint C
    Dec 10, 2002
    420
    Wiltshire UK
    +4
    Thanks for the reply guys... keep up the good work.
    I do have one question though... it's been mentioned that the AE300 doesn't do 1:1 pixel matching "yet"? What's going to change to make that possible? Either it's matches or not right? Would it be dependant on a graphics card manufacturer offering the required resolution?
  6. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    AFAIK, it's an issue with the firmware in the projector - it doesn't have anything to do with graphics cards not being able to do the resolution.
    There's discussion galore (and a couple of very long threads) over on avsforum about this issue - also interesting info about the Bravo dvd player which has dvi output, and which has had it's firmware upgraded by the developers to cater for the AE300.
    Sean G.
  7. Clint C
    Clint C
    Dec 10, 2002
    420
    Wiltshire UK
    +4
    Thanks again... :)
