What input mode for HDTV for PV500?
Discussion in 'General TV Discussions Forum' started by ErikX, Aug 10, 2005.
  1. ErikX
    ErikX
    Sep 14, 2004
    84
    I have just gotten my Snazio sz1350 HD player, and my initally impression is that it serioulsly rocks!
    One n00b question: I have set it up to use DVI 1024*768 resolution as that is the closest to the native resolution for my screen. However, whatever HD content I play, pressing "i" on the remote tells me that the resolution is 720*480. Does this sound correct?
    Edit: Hmm...if I set it to DVI-1080i the resolution reported by "i" is 1920*1080, if I set it to DVI-720p the resolution reported is1280*720.
    What should I choose?
