What input mode for HD to TH37-PV500?
Discussion in 'Plasma TVs Forum' started by ErikX, Aug 10, 2005.
  1. ErikX
    ErikX
    Sep 14, 2004
    84
    I have just gotten my Snazio sz1350, and my initally impression is that it serioulsly rocks!
    One n00b question: I have set it up to use DVI 1024*768 resolution as that is the closest to the native resolution for my screen. However, whatever HD content I play, pressing "i" on the remote tells me that the resolution is 720*480. Does this sound correct?
    Edit: Hmm...if I set ut to DVI-1080i the resolution reported by "i" is 1920*1080, if I set it to DVI-720p the resolution reported is1280*720.
    What should I choose?
  2. k0rn
    k0rn
    Just set it to 720P and you´ll be fine.
    The Pv500 does only accept true HD resolutions via HDMI/DVI. Therefore, 1024x720 etc are show dissorted.
    Whatever, 720P gives you a stunning picture... be sure to set the sharpness of the PV500 to max for HD content. Helped me a lot and good HD material doesn´t need any blurring... :D
