What (If any) Sound Cards give DTS output
Discussion in 'Computer Components' started by Stewart C, Nov 14, 2000.
  1. Stewart C
    Stewart C
    See subject
    Regards
    Stewart C
    An amateur but an enthusiast
  2. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    StewartC,
    Depends on your budget and the ambitions I would suggest the following:
    1. CHEAP version: SBLive Value + HoonTech bracket to give you S/P-DIF (both optical and coaxial); or
    2. MEDIUM version: m-audio Audiophile 2496. This is superb card with both S/P-DIF and analogue outputs, and would easily over perform majority of high end DVD.
    3. EXPENSIVE. Don't have a proper advice.
