What Hifi and Signature 805s
Discussion in 'Home Cinema Speakers' started by klnc, Apr 28, 2003.
  1. klnc
    klnc
    Oct 2, 2002
    385
    London
    +36
    Quote from a review by What Hifi of the Signature 805s on the B&W website
    http://www.bwspeakers.com/index.cfm.../ObjectID/EEE764FF-E324-4501-A09965AA5BEEC437
    "Bi-wiring is essential to make the most of the impressive transparency, as is a pair of sturdy supports."
    Now i take the bit about the supports, but are they talking rubbish on the bi-wiring - i thought most people don't give that the time of day anymore?
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    Aldershot, Hampshire
    +295
    I bi-wire my front speakers both l+r + centre speakers. I noticed an improvement after bi-wiring- seemed to be more detailed repro imo. give it a go and see if u notice a difference.
    The B&W manual suggests you get a better preformance with biwiring and should do so to optimise their performance. I'm not going to argue with that. The only down side is having to fork out for more cable, but I thought it worthwhile in the end.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    A mate of mine has a pir of 602s3's and while demoing at sevenoaks the salesman offered that they would sound better with good single wire than bi-wire. And according to him they did. I think its very subjective and other factors such as placement can have a bigger impact.
  4. Manuman
    Manuman
    But what if you were to bi-wire with good cable, rather than with 2 'lesser' cables?
    Ive biwired my current b&w's and i too notice a slightly clearer/more detailed sound.
  5. mark67
    mark67
    I have a pair of the 805 Sig's, I haven't Bi-Wired mine. I have used Townshend Isolda Speaker Cable. They sound the dogs B*****. So why bother? I know some people like to bi-wire, and that fine if thats what they whant.
    Go to www.groovehandle.org you get a better answer than on here it is more HIFI orientated.
  6. kryten
    kryten
    Apr 9, 2003
    557
    Swindon
    +18
    Can't bi-wire my Dyns - saves all the messing about :)
  7. sounddog
    sounddog
    Dec 11, 2002
    3,440
    107
    Leicestershire, UK
    +477
    Yeah ... but that also means you can't bi-amp them either :( which maybe a complete red herring and if you could bi-amp them there may be no difference to the sound ... but you don't even get the option of trying.
    edit ... typed "would" instead of "could" ... though "may" is an even better word so I'll put that in instead
  8. Gambit
    Gambit
    Me too:D
    I'm not worried abou the inability to bi-amp vicky/stef - there's plenty of pre/pow combo's and expensive integrateds to play with :p
  9. kryten
    kryten
    Apr 9, 2003
    557
    Swindon
    +18
    I _have_ bi-amped Dyns in the past in the car, but they really sounded better fed lots of power passively through the Dyn crossovers.
    As said above, there's plent of other things to play with....
  10. Miles@9
    [email protected]
    Jan 17, 2003
    84
    London
    Any one tried doubleing the amount of cable into their speaker.
    Not twice the lenght. I mean two lots of cable. Isn't this all your doing when you bi-wire?
  11. NicolasB
    NicolasB
    Oct 3, 2002
    6,514
    Emily's Shop
    +920
    Can anyone explain how bi-wiring is actually electrically different from using a single wire? In both cases you're applying the same signal to both sets of terminals; it's just that in one case you're connecting one set of terminals to the other with the speaker's built-in shunt, and in the other case you're using two lengths of speaker wire (terminal 1 to amp to terminal 2) with the signal applied in the middle.
    Bi-amping I can certainly see the advantages of, both in terms of taking strain off the power amp, and in terms of simplifying the cross-over process. But neither one of those applies to bi-wiring, unless you can somehow arrange for there to be no electrical connection between two sets of terminals at the amplifier end.
  12. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    My 805s were single wired with Kimber 8TC when I got them,and with all the advice to biwire,I tried,and was quite surprised by the extra detail and smoothness....no problems hearing the difference immediately,and that's using fairly hefty cable,and amps which arent going to clip.
    Highly recommended even if it's just to give it a try.
  13. klnc
    klnc
    Oct 2, 2002
    385
    London
    +36
    Thanks for the replies chaps... Sorry didn't mean to start another debate about the benefits or not of bi-wiring was just interested why the reviewer was adament that these particular speakers must be biwired. Will certainly be trying these speakers out in the near future - haven't heard anything but praise for them!
