What headphones for Home cinema..........?
Discussion in 'Headphones, Earphones & Portable Music' started by (GTV)Chris, Jan 8, 2005.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    If you have little children, or a wife that goes to bed at the same time my Grandma used to do....
    Is there a second best option of using headphones, probably wireless.
    I have a projector etc and love the big sound, so my question is.
    What are the best headphones to buy - my budget is about £100.
    Chris
  2. Jules
    Jules
    Oct 11, 2000
    5,076
    +754
    Sennheiser HD580's. Not the 590's or 570's as they use a different driver which sounds harsh.
    The 580's or 600's are brilliant.
  3. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    Cheers,
    Can these recreate or try to recreate, surround sound.
    I have seen various dolby surround headphones but didn't know if they were gimmiks?
    Also - is there a way that the subwoofer can still be active but the rest of the speakers be off, so at least I can still feel the bass?
    Chris
    P.S your little quote is from Naked Gun, I think? The only film that made me dribble my scrunters in the cinema (although in my defense, I had had a large coke, you know, the one the size of a wheelie bin)
  4. Suave
    Suave
    Jul 30, 2004
    4,878
    +713
    HI GTVChris!
    Have a look on the post about the Pioneer SE-DIR800C Dolby Digital/DTS Surround Sound Headphones - it might help you!
    Suave!
  5. Jules
    Jules
    Oct 11, 2000
    5,076
    +754
    The 580's and 600's are open back design, which apparently works better with Dolby Headphone (and similar technology) than closed back designs.
    I personally think Dolby Headphone is a gimmick and can make some things sound like your inside a toilet, but it does reduce listening fatigue.
    Oh... and the quote is from Naked Gun 2½.
