What HD can this thing do??
Discussion in 'Plasma TVs Forum' started by HadleysHope, Apr 22, 2007.
  1. HadleysHope
    HadleysHope
    Ok, so I just bought a PS3 and don't have much money left! I came across this TV and its really cheap! I realise its by no means a great TV but its the cheapest HD TV thats 42" that I have found. Problem is I cannot find out any more info on it, I have searched all over but no where is it listed what HD modes it will do. Clearly its not going to do 1080p but 1080i would be nice. Can anyone tell from this spec what its able to do? does anyone know anything about this TV?
    Thanks in advance for your help, it is appreciated.
    HH
    Wharfedale W42H40PE 42in HD Ready Plasma TV.
    Television Picture Quality
    High Definition Ready.
    42in (106cm) TV with 106cm visible screen size.
    Resolution 1024 x 768 pixels.
    Brightness 1000cd/m2.
    Contrast ratio 3000:1.
    Connectivity
    HDMI socket.
    2 SCART sockets.
    PC input socket.
    Rear AV socket.
    Sound Quality
    Nicam sound.
    2 x 10 RMS power output.
    Additional Features
    Teletext.
    Fastext.
    UHF and VHF tuners with hyper band.
    Auto setup.
    Auto search tuner.
    Auto search sorting.
    Auto search labelling.
    Sleep timer.
    Child lock.
    NTSC compatible on playback via scart.
  2. stranger
    stranger
    May 29, 2003
    2,551
    5
    137
    Manchester
    +868
    It will (should) do 720p and 1080i via HDMI.
  3. HadleysHope
    HadleysHope
    Thanks Stranger.
    HH
  4. Jungle Fred
    Jungle Fred
    Dec 6, 2006
    48
    I don't know what price you have seen it for but they are £500 at argos.co.uk (new).
  5. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    fwiw, "HD Ready" means 1080i must be supported
  6. pyrotenax
    pyrotenax
    Apr 3, 2006
    976
    3
    4
    47
    Omnipresent
    +153
    Supported yes , but doesnt mean it can display 1080i 1:1 , and therefore scale it down.
  7. HadleysHope
    HadleysHope
    You guys rocks. Thanks all.
    HH
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Just accepting the signals does not mean it's not a pile of poo though. All of these european 'second rate' brand names are what we call SKD designs. They are bought as a kit of parts in China, imported and assembled in EU for tax reasons. The parts are often world generic, and 80% of the world runs it's video at 60Hz. A moderate amount of HD is 60Hz, but all pal stuff is 50Hz, and may not work that well. You have been warned.
  9. HadleysHope
    HadleysHope
    Well it will be replacing a Goodman 42" plasma SD, which (by your definition) is also a second rate european brand. At the end of the day, I have enjoyed over 2 years of my goodmans and feel I want something that supports HD at least in sime respect. This is perfect as I am on a tight budget. I wish I could just throw another 2 or 300 quid at it but I dont have that to spend. Of course if you would like to forward me the extra cash please know it would be welcomed :) hehe.
    This TV will be at the very least better than what I have, and while I realise that it is not to everyones taste it will be fine for me.
    Thanks for your comments though.
    HH
  10. HadleysHope
    HadleysHope
    I just wanted to update this. I went ahead and bought this TV. It does 1080i (prob upscaling or whatever its called) but I have to say how impressed I am with this TV, it really is soooooo much better than what I had before and for £499 I really don't see how you can go wrong. I am really really dead impressed with my purchase. And really, only AV Snobbs are going to tear this apart after seeing it.
    For the cash, I cant recommend this enough.
    HH
