Hi! just wanted to ask what brand hard drive does the PS3 use?
E Elecktro Standard Member Apr 20, 2007 #1 Hi! just wanted to ask what brand hard drive does the PS3 use?
E Elecktro Standard Member Apr 20, 2007 #5 ic..thanks ppl! i was thinking of upgrading my hard drive to a larger capacity. ...will probably go with a larger capacity seagate as the ps3 already uses them oh btw..does it really matter what speed (rpm) it is or not?
T Tony Hoyle Well-known Member Apr 20, 2007 #6 PS3 uses 5400. You could put a 7200 in there but it would generate more heat (and potentially more fan noise).
S small358786 Banned Apr 20, 2007 #8 I fitted this one http://www.overclockers.co.uk/showproduct.php?prodid=HD-011-FJ&groupid=701&catid=14&subcat=896 ordered Sunday night got it Tuesday afternoon,doddle to swap it over as well.
E Elecktro Standard Member May 5, 2007 #9 sorry just one more question..since i don't know too much about hard rives..does the PS3 support or work fine with dual-platter hard drives?
Naqv Well-known Member May 5, 2007 #11 If its 2.5" and SATA, it will work with the PS3. You don't have to get seagate, any company's hard drive will work. Dual-platter will work.
