What happens when i cancel SKY - Dilema
Discussion in 'Sky Digital TV Forum' started by Barrichello, Apr 27, 2007.
  1. Barrichello
    Barrichello
    Jan 14, 2007
    15
    I have had sky for over two years now - in order to save costs im going to cancel my Sky for some time.
    My question is though, when i cancel do i normaly keep the box? I actually still have a old one from when my parents cancelled theirs - so im thinking the answer is yes.
    The reason i ask is that i dont actually have a External aerial on the roof, so i cant really use the inbuilt free view on my tv without one. If i get to keep the box and the sky dish though - will i be able to still receive basic freeview via it? or is there a way i could put the sky dish feed-line straight into my tv to act as a external aerial?
    Any help appreciated :)
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Your last idea won't work.
    However, you get to keep the box and your old subscription card acts as a Freesat card so you'll get all the basic channels + a few more.
    (and this thread really belongs in the Sky/Sky+ section).
    Chris Muriel, Manchester
  3. Barrichello
    Barrichello
    Jan 14, 2007
    15
    Yeah thread was moved - i was a bit drunk when i posted :thumbsup:
    Cheers for help - sounds good so at least i can use the set top/card to get bbc1-ch5 and a few of the free ones e4 etc?
  4. Barrichello
    Barrichello
    Jan 14, 2007
    15
    Ah freesat i see...
    Like this.....
    http://www.freesatfromsky.com/?pID=2
    Says you get 200 channels - not bad for it being free :)
    so basically keep the box and card and i can use this - is pretty good.
  5. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    E4 is still classed as a PAY channel on satellite, the Freesatfromsky service is not the same as Freeview so while there are dozens of more TV and Radio channels on satellite there are some noticeable exceptions:)
    The BBC/ITV announced their "Freesat" service coming Spring 2008 which should mean a wider choice of set top boxes including DVR's and CH4 along with E4 and More4 should be going in the clear around the same time.
