What happens when 24bit/192khz signal is fed into AVR350?
Discussion in 'AV Receivers & Amplifiers' started by ReferenceLover, Dec 29, 2006.
Tags:
  1. ReferenceLover
    ReferenceLover
    Nov 30, 2006
    53
    If I feed 24bit/192khz signal via optical link, what would AVR350 do with the signal? Will it decode the signal OK?
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Umm.... nothing will happen because such SPDIF links don't generally run that fast.... also you can't get high resolution outputs from copy-protected media (such as most DVD-Audios) over SPDIF. They are limited by the licence arrangements to 16 bit 48kHz stereo.
    Use the analogue connections instead.
    Hope this helps!
    John Dawson (Arcam)
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    Wot e sez is rite.
