what happened to dolby digital on sky
Discussion in 'Sky Digital TV Forum' started by paulefox, May 18, 2003.
  1. paulefox
    paulefox
    Feb 8, 2003
    1,293
    Bury St Edmunds
    +43
    It seems to have gone.
    i ahve had a look through sky movies widescreen and they dont seem to be broadcasting in it now.
    has something gone wrong ?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Perhaps the switch to more widescreen and DD5.1 movie channels (June 3rd) includes a physical movement of the playout hardware that has been used for Premier W/S.
  3. chard
    chard
    Dec 12, 2002
    398
    16
    Damn, just copied Spy Game on the w/s channel and noticed that it is DS not DD.....
    anyone know what's going on ?
    looking forward to June 3rd.
  4. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    What's happening on June 3rd?
  5. chard
    chard
    Dec 12, 2002
    398
    16
    they are meant to have 3/4 Premier channels in 5.1 ..........plus Sky One and Sky One Mix in w/s.
    Some 130 5.1 movies in 5.1 in June alone !!
  6. GETanner
    GETanner
    Mar 11, 2002
    572
    +76
    I would check your equipment.
    I recorded Spy Game on the 17th at 8pm and my Denon amp is using a 5.1 signal (all 6 red lights are on).
    Guy
  7. Fairzo
    Fairzo
    Apr 8, 2002
    107
    16
    So did I and it claimed to be in DS on both the banner and on the Sky screen immediately before the film starts. Have to say it did sound better than most DS soundtracks although it's difficult to be objective without being able to make a comparison.
  8. asimm
    asimm
    Aug 3, 2000
    1,516
    48
    +75
    Chard
    I watched Spy Game and it was DD - one of the best I have heard (helicopter scenes were great). Maybe the EPG and pre-film screen just got it wrong. I doubt after they have invested so much in Sky plus that they would drop DD.
  9. chard
    chard
    Dec 12, 2002
    398
    16
    thanks chaps, I must admit I took the on screen info at its word and watched Spy Game on the bedroon telly as I didn't expect 5.1.
    This sounds like mis-labelling, which is apparently still happening tonight, must check what my amp says....
  10. chard
    chard
    Dec 12, 2002
    398
    16
    yep, the problem is the info on Sky...just checked Tigerland, the amp says 5.1 but the info box says DS......
  11. paulefox
    paulefox
    Feb 8, 2003
    1,293
    Bury St Edmunds
    +43
    yes I have now found the same
    thanks for your help
  12. Family Guy
    Family Guy
    There is definetly a problem with the banners advertising movies actually broadcast in 5.1 as DS...
    Harry Potter and The Philosophers stone was broadcast in EX with the EX channel flagged as well. Put my Yammy 630 in Dolby EX mode when it was in the auto mode. I can't remember that happening before. Even the DVD for that particular movie isn't flagged EX...
  13. mps
    mps
    Oct 16, 2001
    1,511
    London
    +52
    I was watching Vertical Limit Tonight on Premiere Wide and no 5.1 sound at all yet pro logic was okay.So there is something weird going on with their broadcast.Any one else encountered the same.
    Cheers.
  14. Jules
    Jules
    Oct 11, 2000
    5,102
    +773
    Yes,
    I flicked over to moulen rouge (or what ever its called) last night on premier wide. It was silent for the first 10 minutes, then when the sound came back, it was only in DS.
    Its wierd because I'm sure previous screenings of the same film on premier wide were in DD.
    Something is definately going on.
  15. mps
    mps
    Oct 16, 2001
    1,511
    London
    +52
    Also anybody noticed the auto widescreen switching facility is not available either.
    Cheers.
  16. Family Guy
    Family Guy
    Mine flicks backwards and forwards from WS OK - you might need to check your settings. Could even be your SCART cable - pin 8 is the pin that carries the signal to tell the TV to change.
    Star Trk Generations was only in DS last night. I watched that before and it was defo in DD 5.1.
    However, if you go forward to Tuesday in the EPG, you will see that Premier wide is no longer available. There seems to be a fair share of decent movies in wide spread accross the rest of the movie channels...out of all of Tuesdays films on after 6 PM on Premier 1, 2 & 3, I think probably 80% of them are flagged DD...only time will tell.
