Quantcast
What graphics cards support 1400x1050?
R
Razieluk
Can anyone help with this, as it seems the card I wanted doesn't support this resolution?
Raziel
R
Razieluk
Because my new 20" LCD monitor is that resolution.
My current card doesn't support it and having it on the lower resolution - 1280x1020 (I think) - means that some of the text is a little blurry depending where it is on the screen. So if I scroll the text up a bit it's fine, but if it goes up a bit further it goes slightly blurry again, and so on.
I've read somewhere that LCD monitors need to be at exactly the right resolution to make the text crisp and clear (yes, I have got Cleartype fonts on).
Raziel
