what gains with prog scan?
Discussion in 'Plasma TVs Forum' started by minder, Sep 29, 2004.
  1. minder
    minder
    Just received panny th42pe30 ...brilliant, but im using multiregion toshiba 220 ...no prog scan, what gains would I see if I buy latest toshiba 240 or pioneer 575 that have it. thanks
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    It is better, but some people don't really notice the difference...best thing is to get a new player on loan and see if YOU can notice the difference...:smashin:
    JJ
  3. ihan
    ihan
    Sep 10, 2004
    655
    28
    Stockport
    +25
    It depends upon the quality of the de-interlacer in the DVD player. With my old Sony 930 player & my current Arcam DV79, progressive scan enabled in the dvd player is a very worthwhile upgrade over using the deinterlacer in the PW6. The main improvement is no 'blurring' or 'ringing' of dark edges on a light background (or vice versa).
    Regards,
    ihan
