What 'gain' do I need....(Beamax screens)?
Discussion in 'Projectors, Screens & Video Processors' started by chalkstorm, Nov 5, 2005.
  1. chalkstorm
    chalkstorm
    Jan 19, 2004
    433
    Rugeley
    +8
    Just building a HC - in a dedicated room. Will be almost complete darkness - and plannign to use either a Screenplay 5700 or 7205. Projector will be approx 15' from screen - and I plan a 8' diagonal.
    Just looking at the Beamax range - but some have a gain of 1.0 - while others are 1.5
    Could someone please guide me as to what might be best?
    Thanks in advance
    Simon
  2. kurtz
    kurtz
    Feb 15, 2004
    173
    last place you'd look
    +23
    I'd have thought that unless you need a bright picture for sports viewing then 1.5 gain would be too much. Those Infocus projectors are known for being bright. For a 96" screen in a dedicated room a gain of 1.0 should be plenty, even with the bulb in economy mode.
  3. chalkstorm
    chalkstorm
    Jan 19, 2004
    433
    Rugeley
    +8
    Thanks Kurtz - not being a sports fan - and the room will have the ability to be very dark - I'll look at the 1.0 gain screens.
    Kind regards
    Simon
