What first......to shell or to remote?
Discussion in 'Desktop & Laptop Computers Forum' started by buns, Apr 28, 2002.
  1. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I am intent on putting a shell type thing, such as talisman, onto my hcpc, also it will be remote girder controlled......but which do i do first? I havent used talisman or the likes, so i dont know how it works. Do i set it up, and then use control talisman via remote, or do i remote control everything, and then stick talisman on top?
    thanks
    ad
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,871
    87
    Newcastle
    +123
    Huh??
  3. Jenz
    Jenz
    I used Talisman. Heavily locked down the desktop, has been totally stable for months, hate girder dont use it, control everything still with a Pronto.
    Try that first ;)
  4. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,859
    71
    Laindon Essex
    +97
    Wotcha Buns,
    Haven't tried Talisman so can't comment, but i understand it's quite an art to master (but then again so is Girder)
    My own setup is very simple i use a standard desktop (no "active desktop" to cause issues) with a tasteful wallpaper running a little proggy to hide the desktop icons another to hide the cursor. I use girder to control dvd genie, set desktop resolutions, (via power strip) to reboot & to turn off computer all these commands are activated using IRman & a Pronto, works perfectly for me.
    I use windvd 3.1 & powerdvd 4 xp
    Tim
    Neil:
    You Got that 9 incher :D yet.......I understand you are moving your setup to another room.....if you need any help moving drop me an email
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Jenz,
    So you use talisman......but no girder? So what IR software do you use? Or does talisman do that too?
    I dont know whether it is worth worrying about all these bits and pieces, but does having something like talisman not give the system a more high end audio/video feel as opposed to a computer? The intention I have is to totall remove windows from view......except for a tab or button or whatever that will remove me from the (talisman for example) environment i have designed, into windows so I can fiddle. Maybe I should get hold of the software and play before i ask anymore!
    ad
  6. Desmo
    Desmo
    Jan 4, 2001
    14,454
    Braintree, Essex.
    +6,501
    Snap
  7. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,859
    71
    Laindon Essex
    +97
    Yo Desmo,
    Great minds think alike eh must be something in the essex water/sewage:D :D
    Tim
  8. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    so what other shells could i use if not talisman?
    ad
  9. GarryF
    GarryF
    Aug 30, 2000
    1,429
    83
    Scotland
    +339
    I'm guessing here but if you use talisman you probably need an IR keyboard, you can then move UP DOWN ENTER etc to start programs after you've trained the Pronto.
    With Girder you don't really have an interface on screen, in my case a totally black desktop with all icons removed (set background to black, turn on active desktop & select hide icons option, set taskbar to autohide and overscan the bottom off the screen) . Pronto then tells girder to start the relevant program, windvd, winamp etc so there is no shell.
    Either way is valid but there's a pretty steep learning curve for girder and going by comments in this thread Talisman is similar. I prefered the limitless (well just about) IR codes I can get with a IRman and girder, I have a button for each album in winamp (few hundred or so) I can launch the music from the pronto without having to fire up the projector so I think it's pretty cool :)
  10. Desmo
    Desmo
    Jan 4, 2001
    14,454
    Braintree, Essex.
    +6,501
    Aye, they certainly do :)
    Not sure it's the water or sewage though. I blame the Alcohol.
  11. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I dont see any reason why you cant use talisman or the likes, then simply use girder to control it......
    does that seem unreasonable for some reason im not considering?
    ad
  12. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,859
    71
    Laindon Essex
    +97
    That's the beauty of the system me & Desmo runs keep it simple....no talisman to suck up resources, no active desktop to crash your system, i have tried all configs this by far is the best.
    Get to learn how to use girder & programme a pronto et-voila HCPC no problemo.
    Stuff i use for my setup:
    Icon hider.....freebie
    cursor hider.....freebie
    Girder.......freebie
    dscaler.....freebie
    powerstrip 3
    powerdvd 4 xp
    windvd 3.1
    win 98se
    HCPC runs at 72 & 75 hz via powerstrip activated by pronto,
    HCPC reboots via girder activated by pronto
    HCPC turns off via girder activated by pronto
    HCPC runs dvd genie activated by pronto
    Skys the limit m8
    Tim
    Desmo: The water is the sewage innit???:D
  13. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I suppose I cant much argue your logic. I guess unless I get into making the pc a cd jukebox too, the shell is a bit irrelevant.
    Your way i could i suppose customise myself a lovely screensaver.....hehe i like that!
    Maybe a question for another thread or a search.....but is it possible to hide all the text and stuff that you see at boot up? ie could i get a screensaver of my own design to hide it all.....much like a piece of gear you would buy......
    ad
