What external dvd-r burner is best value
Discussion in 'Desktop & Laptop Computers Forum' started by Molly, May 13, 2003.
  1. Molly
    Molly
    Jun 15, 2001
    212
    Lincolnshire
    I'm looking for a good value external dvd-r burner.
    Would it be better to connect via usb2 or firewire?
    Any recommendations.
  2. Kramer
    Kramer
    Well it's not cheap, but this one looks OK.
    Has both firewire & USB 2 so you can tell us which is the better option should you buy it :)
    Not too many external DVD writers available.
  3. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
  4. Molly
    Molly
    Jun 15, 2001
    212
    Lincolnshire
    Thanks for the replies.
    If I connect an external writer directly to my USB2 will this power itself from the laptop or do I need an additional power cable?
    I assume a external IDE model with the external case would need powering seperately.
  5. Kramer
    Kramer
    99% sure you'll need an external power source too.
